CDG+MP3 export problem
franks
Post by franks »
Imported a KTP file with an AIFF audio source into kJams(vD70)
Then when I export the 'entire playlist:all files' from kJams, I get the original AIFF file, .xml file but NO CDG file and NO MP3 file
Can You enlighten me.
Should I convert the AIFF file to an MP3 file before generating a KTP file, then bring the KTP file into kJams?
I didn't have to do this before
Re: CDG+MP3 export problem
1) you have to purchase the Producer plugin if you want it to produce CDG files.
2) you have to convert the aif to mp3 if you want kJams to give you an MP3 (you can do this within kJams)
franks
Post by franks »
Dave,
Yes I have Producer plugin.
But since this post I have resolved the problem
The problem was that the LAME MP3 installation packaged was not automatically installed when I downloaded the updated kJams version on this computer. So I manually installed it.
I had also posted this as a "bug" report.
Everything is fine now.
Thanks for your quick response.
