Burning plugin won't install
trotsky
Post by trotsky »
Installing kJams on a new machine (New Mac Mini, Snow Leopard 10.6.3)
Can't install the burning plugin
The installer runs without issue, but when I open kJams, I get an error "There was an error moving "Burner.bundle" into the folder "kJams Plugins": afpAccessDenied, insufficient access privileges for operation"
I adjusted rights to that folder, tried to reinstall, still no luck.
Help!
(Thanks!)
Re: Burning plugin won't install
i've had a half a dozen reports of this.
please get me on iChat so i can look!
i've asked everyone to get me on ichat to fix this but nobody has followed through. please help me fix this by getting me on iChat.
trotsky
Post by trotsky »
Just sent a message to you via iChat.
yes, but you have to message me when i'm actually online :)
franks
Post by franks »
I had same problem but followed linkhttp://karaoke.kjams.com/wiki/Permissions instructions in resetting all permissions.
SOLVED THE PROBLEM!!
:D
