Bit Rate Column
dizzidecazz
Bit Rate Column
Post by dizzidecazz »
Hi,
I often find myself with various versions and duplicates. It'd e handy to see the Bit Rate of the versions when choosing which one will be a star and which is off to the glue factory. A column would be cool.
Re: Bit Rate Column
gotcha, i'll add that to the list
dizzidecazz
Re: Bit Rate Column
thanks dave.
Re: Bit Rate Column
Re: Bit Rate Column
will be in the next release
