Ripping
djdave
Ripping
Post by djdave »
I got all my Sound Choice Foundation discs to rip, but when I inserted an All Star Karaoke disc, not only can't I find any meta data for it, it will not eject. Any ideas?
Re: Ripping
Re: Ripping
I have had problems with these A.S.K discs also. Don't buy them anymore, they suck
Re: Ripping
:evil:
djdave
Re: Ripping
Post by djdave »
You guys are genius! The sharpie trick is working. Thanks!
Re: Ripping
JOY!!!!! :D
Re: Ripping
This really works? lol, how did you mark your disc? Very Carefully? :D
Re: Ripping
the link above about discs sucking has info on where to mark your discs
Re: Ripping
Yeah, i know but just wondering if he did anything other than what is documented :D
Re: Ripping
</wondering_still>
djdave
Re: Ripping
Post by djdave »
Sorry the reply took so long.work, work, work.
I did the sharpie work by hand. I did make a mistake or two, but was able to erase with a clean cotton towel and redo with more accuracy. There was a suggestion to make a template, and I believe that's a good idea.
Re: Ripping
:shock:
