More of an "issue" than a "bug"...
Jon Leggitt
Re: More of an "issue" than a "bug"...
Post by Jon Leggitt »
As an point of interest, I've been able to mitigate the majority of the lag by making sure that the library sorted by "#". I take it that the library runs a sort operation every time you load it?
Not perfect, but at least I don't have to wait until a musical break to load the library anymore. Any pause in the lyrics sweep will do now.
For even faster sorting, sort by PLI :)
best performance of course is on an Intel mac.
Note: with Snow Leopard not supporting PPC macs any more, you know it's a matter of time now until kJams can no longer support PPC machines.
whatislove
Post by whatislove »
While I can appreciate wanting your userbase on decently fast hardware... I would hope that a 1.33 ghz g4 with 1.25 or 1.5 G RAM could be pressed into service with full functionality.
you may hope, but until i get into beta, i am not concentrating on optimization. I definitely plan to do very aggressive optimizing once i get into beta.
keep in mind however that the minimum requirement will remain 2 GB of ram. and i will eventually be completely dropping support for PPC machines (because that is what Apple is forcing upon us with the OS). in general i support 2 revisions back on the OS. so if Apple is at 10.6, then i will support 10.4. This means when Apple is on 10.8, then the minimum supported system for kJams will be 10.6 which is intel only.
