quicktime export plugin purchase?
Re: quicktime export plugin purchase?
1) I notice it briefly opens up all (or a lot of) the files saying "unpacking audio" (something like that) in the activity window.
that right there is the problem. It should only unpack the same number it's going to export at once. Unpack more and you'll get file not found.
heck i tested that on my computer first, must be something still missing. allright i'll look again tomorrow night and try to fix it, i'll keep you posted, sorry for the hassle!
Previous versions here
acemc
Post by acemc »
No problems at all.
Thanks for the link.
i just tested again AND checked the code and it's definitely working correctly. which leaves me wondering what's going on on your system.
please send me your preferences file (help->reveal prefs)
acemc
Post by acemc »
Sure thing.
kJams Preferences.plist.zip
(5.21 KiB) Downloaded 425 times
Hope this reveals the problem.
your "number of cached songs" is 233, should be 25. but i can't see how that could cause any problem. hmmm....
if you can reproduce the problem reliably, we should probably just get on the phone again...
acemc
Post by acemc »
It does it all the time now. Even with V1.0.1.20.
If I export more than 1 at a time I get the errors.
let's get on the fone
if you're there now, call me
acemc
Post by acemc »
Gonna call u now.
