Last version kjams video fullscreen
joaocrs
Post by joaocrs »
hello all,
I upgraded to the latest version kjams (1.0D52r60 mac version) and now when I activate the "mission control" the video window is not fullscreen.
Does anyone have the same problem or know how to fix this?
Re: Last version kjams video fullscreen
was it working on an earlier version? can you tell what version it broke in? how to downgrade
joaocrs
Post by joaocrs »
dave wrote:was it working on an earlier version? can you tell what version it broke in? how to downgrade
the latest version that was used was 1.0d52r56.
I use macbook pro 2011 with mountain lion
joaocrs
Post by joaocrs »
I did the downgrade to 1.0d52r56, problem solved.
Are you going to solve the problem in a new update?
i'll look into it, thanks.
fixed! thanks for the report!
joaocrs
Post by joaocrs »
Hi Dave,
I did the update again to version 1.0D52r60 and the problem continues.
