Search as you type
natblend
Search as you type
Post by natblend »
My "Update Search Results as you Type" got turned off.
I cannot find the option amywhere in the preferences.
Is it still there?
Re: Search as you type
it will be back in the new release IF you hold the OPTION key when invoking the prefs. Note: if you turn it on and get crashes, you're on your own.
natblend
Post by natblend »
I see it now.
I only have 8,000 songs.
Does that mean I should be alright?
you should be allright yes, give it a whirl
