Hard Drive Snail
arrowheaddj
Hard Drive Snail
Post by arrowheaddj »
Ever since I started re-evaluating my karaoke collection, KJams access to files has doubled in time. Also - I use (2) Macs (one as a backup). When I use my backup, all the file names are unable to be found (since they were re-evaluated on the main computer) and I have to "select: the correct file from a file menu. Is there any way to export a "map" to my backup computer so all my re-evaluated work (22+ hours) on my main computer will match?
Thanks.
Re: Hard Drive Snail
1: what do you mean "doubled in time" ?
2: you must clone your system:
http://karaoke.kjams.com/wiki/Cloning
