Quit without warning
I know I can have "Warn if current song will be interrupted" in the prefs but if I haven't got that checked and I accidently hit cmd Q I quit the program which happened last week.
I was editing some tracks and meant to hit cmd A to select all but I hit the Q and the singer was suddenly left in silence.
Could we have the question "Are you sure you want to quit" appear with the box "Yes" highlighted regardless of the prefs.
Len
Re: Quit without warning
ok easy enough
I hate to be a pain, but do you know when you might do this. I quit kJams again last night by accident.
you are not a pain, you are correct.
i will do it this week.
That's not what the wife says
:shock:
I have to congrat you with the option you put in for this feature but I do have another request, any chance of a window to ask if I want to close the program whether a tracks playing or not.
I know if I'm using iTunes I don't get the window if I click ⌘Q but I don't work in iTunes like I do in kJams. I'm obviously a bit clumsy because the number of times I click ⌘Q instead of ⌘A is unreal.
I must get more sleep.
i'll add it to the list
