Help me, I'm a noobie!!
coliekat
Post by coliekat »
HI!
I work at a company that needs to be able to rip and burn karaoke songs onto a playable CD+G.
I really need a step by step tutorial on how to do this. I've read that I need a new drive but I don't know what kind to buy for Mac? I've looked and they don't seem to have the CDG capabilities that you were saying the drive needed to have. After I get the proper drive, do I need to get CD+G blank discs or regular CDRW's?
As you can see I need some major help.
Thanks for any help whatsoever!
Re: Help me, I'm a noobie!!
instructions:
http://karaoke.kjams.com/wiki/Burning
drives:
http://karaoke.kjams.com/wiki/Compatible_Drives
Get a LightScribe. They don't advertise "CD+G" and they don't advertise "Macintosh Compatible" but they work perfectly.
Don't use CDRW except to test that your burner works. When you confirm it works, then use regular CDR discs (get a name brand non colored spool)
coliekat
Post by coliekat »
Thanks!!
I found those links after I posted. I'm good to go now. Thanks so much for the quick response.
This is very cool!
