Mixed font size
Mixed font size
After saving my tine prompter file and importing it into kjams, the text is different font sizes every five or six words. Is this caused by not formatting the words in tune prompter correctly or because i'm using a trial version of producer?
Can i fix this in producer or do i have to go back into tune prompter?
sounds like a bug.
please package up the song and send it to me.
(zip and send .cdg, .mp3, .ktp, .xml)
Dave, i didnt see your mail server was down, i just re-sent the zipped files to the other email address.
got it thanks, i'll try to look at it this week.
Cheers!
this bug is caused by importing from an older version of kJams.
quit kJams, then delete the .xml and .cdg files associated with the song, then run again, should be all fixed.
I tried the above, still having the same problem. Unless i am doing something wrong? I have the latest version of Kjams Pro and Tune Prompter:
quit Kjams, go in and delete the xml. and cdg. files, open Kjams and add to library, double click the ktp. file. This works beautifully but while the song is playing i goto advanced, then open Producer. It converts to cdg. I hit the space bar and the song plays but some letters are missing, before the font size was different. I also noticed that the text from producer are not showing up correctly in the Artwork panel. I do not know if this is related.
I meant" this is not the same problem"
send me the file in question. (all 4 parts, zipped together)
Tim League
Re: Mixed font size
Post by Tim League »
I'm having a similar problem. I'm running the most recent version of KJams and TunePrompter. Im on a new macbook pro running 10.5.7. My track imports fine and plays perfectly. When I open Producer, the first word of each line on each screen is small and the timing between screens is screwed up.
Now, I haven't bought Producer yet. I wanted to try it out before purchasing. Does this have anything to do with not purchasing, or is this another problem entirely?
Tim League
Re: Mixed font size
Another problem. Went ahead and created the CDG file. I know the red x's are there because I haven't bought it, but it's also dropping characters now. Screen grab attached here: http://pk.gd/GzM.
Not sure what is going on with either problem.
Re: Mixed font size
well send me the files so i can take a look, this should not be happening.
did you create these with an older version of kJams?
Re: Mixed font size
Sorry to say it Dave, but it's happening here too.I have screen shots, but I guess that's already covered. FTR, interestingly, when not using producer, the file is playing with the first word superscripted (smaller and raised baseline.) This may be a clue as to what is happening. Also, it is not seeming to be respecting "viewsafe" borders anymore.
You know how to contact me,
Your annoying little ß (pre-α according to you) tester guy.
SpiritusInMachina
Re: Mixed font size
well as soon as SOMEBODY sends me some files to look at, i can check into it. so far, nobody has follwed up with me.
