perfect Metadata
BlackJack86
perfect Metadata
Post by BlackJack86 »
When correcting song names or artists for consistency, if I only do 1 at a time it works ok. When I do a group of songs at once, when I make the changes and hit "OK" or "Return key", it takes me back to the top of the library list. This is very time consuming, especially since with a large library it is almost impossible to get to the specific song area quickly.
Re: perfect Metadata
make sure you're sorted by "PLI" or "Song ID" and definitely not by "Song", "Artist", or "Album" or anything you can change in the "Get Info" dialog.
if it STILL scrolls back to the top, try hitting the down arrow after, this should take you just below the last selected song? let me know.
