I have tried to remove a faulty zip, when i do so, the program crashes.
I cannot rename either. Don't want the program to crash in the middle of a show because I have two files the same name this is the latest fix
Also, the video thing DID NOT WORK! The TV kept going crazy, like a video that needs tracking, the picture would not sit still, there is no tracking on my simple tv. The big screen would not even pick it up at all.
I am going to bring my big computer monitor in, maybe that will do it!
If I cannot get that issue resolved I don't know if I can use this program
Thanks for all your help!
Crashes when i try to remove something
It ain't a contest, so get yer yella teeth and bad liver down here and sing!
there is a bug right now where it will crash if you try to delete a song that is otherwise being used (playing, unzipping, zipping, meta push / pulling, saving database etc). the simple solution is to keep the tasks window open and watch it. don't delete songs when there are tasks. keep in mind that the push / pull tasks take 10 seconds to show up after you change any meta data. so this bug is quite easily avoided.I have tried to remove a faulty zip, when i do so, the program crashes.
this has nothing at all to do with kJams. I am guessing your display prefs are set to PAL vs. NTSC for your TV.Also, the video thing DID NOT WORK! The TV kept going crazy, like a video that needs tracking, the picture would not sit still, there is no tracking on my simple tv. The big screen would not even pick it up at all.
I had an issue with my laptop doing weird things on the tv. There would be some bars coming across the screen like it was redrawing very slowly, and I started to notice the issue on my actual laptop screen as well. A few searches (frustrating) at support.apple.com turned up similar issues with other versions of operating system, so I tried the suggested fix of zapping pram. Worked like a charm. The process for doing that apparently also zaps vpram or whatever the video card equivalent of pram is.
Shut down computer
Restart holding down command-option-p-r
Apparently if you get the grey screen before you have the keys held down you'll have to try again.
Your mileage may vary, but the problem you're describing sounds similar to what I ran into.
Shut down computer
i have figured it out. and i know what needs to happen.
tho it's rather a lot of work.
i'm procrastinating.
and telling people "don't delete stuff while it's in use"
but eventually, of course, it will be fixed.
Update: Oh, you were responding to Herb Girl, right i see. i thought you were encouraging me to figure out what the bug was
sadly i think we've lost her to the dark side
