only a few songs show up on each singers list
mikefala
Post by mikefala »
I was finally able to upgrade to a new Apple Silicon M1Pro x 16 laptop. updated to Monterey 12.01 "Restored" the new laptop from a time machine backup of my currently operating fine but now "obsolete" MacBook pro Mid 2009 running elCapitan. Purchased a new license for kjams pro with my new e-mail identity and everything seems to work fine ie the music files moved; the library seems intact and the files play and sound fine. However my singers list view says for instance 100 songs, 500 songs, 30 songs,etc at the bottom of their respective window. However each singers list shows only 3 songs. If I add a song to the list it shows up on the "mini monitor" list and adds 1 more song to the total count at the bottom. so now 101, 501,31. How can I rebuild the list view to include all the hidden/missing songs for each singer. Also what is the mini monitor pane? that never showed up in the 32bit versions before.
Thanks,
Mike Falaschi
formerly [email protected] now [email protected]
Re: only a few songs show up on each singers list
that means kJams thinks you're in Tryout mode
are you?
i don't know what you mean by "mini monitor" pane. please take a screen shot
