Delay store tag to file
I set the Delay time after editing to store tags to file to 600.
Can't take more than maybe 20s
Re: Delay store tag to file
you're right it maxes out at 20 seconds. this should be more explicit, i'll fix it.
later: the dialog will now self-correct if you switch pref panels and go back, it will clamp between 1 and 20
