Send logfile from Help
Help/send log crashes with:
Mail starts but no new email, while kJams crash in background.
kJams 2.log.zip
(2.96 KiB) Downloaded 912 times
Re: Send logfile from Help
i'm not seeing that. when i get around to this bug, i'll email you, we'll schedule a time for screen sharing, and i'll have a look at your computer
are you still seeing this problem with the b41?
b42, yes
can you text me so we can set up a time that i can look at this?
still not working.
it switch to mail but then kJams says
"not auth...to mail" dialog shows.
Not crash though
what you are seeing is working as expected. you have to go to system prefs->security->privacy, and give kjams permission to script the finder
Is that under "Automation" ...can't add apps there.
kJams has full disc access and Accessibility.
Yes, under Automation. kJams should appear there, and you have to check the checkbox next to it.
If it doesn't show up there, i've added a new entitlement for apple-events, check again after the next update
Worked perfectly!
