Why doesn't iPad need WKTJams?
What is the difference between iPads and iPhones in that I can just use a browser with my iPad and need to use WKTJams with my iPhone?
Also, how do I find or reset my password when I log into the server? Nobody here uses either, but just in case someone expresses interest in the sheet I've written up, I want to show them, but I forgot my password.
Re: Why doesn't iPad need WKTJams?
does the browser really work on an iPad? hadn't tried that. i think the drag and drop support doesn't work? have you tried reordering your queue? that's a critical feature. it's supposed to not let you use the web browser.
you reset your password by telling the KJ, you can't do it on the web page.
to reset the pw of a singer when you as the KJ are running kJams, right click the singer and pick "get info"
Re: Why doesn't iPad need WTKJams?
Interesting. Using my browser in my iPad doesn't appear to allow me to reorder my queue. I haven't tried using my iPad in Sidecar for that, as my iMac is too old for Sidecar.
When I tried using the browser on my iPhone, it just sent me to WTKJams. But the iPad let me use my browser—with that one limitation that I hadn't noticed.
Well, I'm in senior living. This is a feature that would be popular with youth. It's hard enough to get seniors to use the spreadsheets and request sheets I've printed up.
what feature are you requesting?
that the iPad ALSO forward you to use wtkJams?
or that the iPhone allow you to use the web UI, but also have the limitation of no drag and drop?
or that you want drag and drop in the web UI on the iPad?
The iPad will use WTKJams. I'm not requesting a feature, just trying to figure out what's different about iPads and iPhones (and computers) here. Unfortunately, the people I do Karaoke with are older and will never use either feature.
I think the simple answer is this code was written before iPads, so it doesn't detect them and re-route users to use wtkJams.
the REASON it reroutes users using iOS is that the Safari browser on iOS simply doesn't support the flavor of drag-and-drop that the kJams server implements (and also that wtkJams has a much better UX).
Interesting. I will try other IOS browsers this afternoon.
it won't work in any browser, i think, they all must use WebKit, i think?
When I try to drag a line item up, it scrolls up. But there are computers and iPad that use both mouse and touch, so it should be solvable.
when you try to drag a line item on iPad?
note my "solution" is to disallow iPads from using a browser: they MUST use wtkJams.
