Crash when audio not found
Rayco
Post by Rayco »
Tried to add a file (CDG and WAV files) and it gives the message;
Assert Fail: songP, in file: 'CBrowserWindow.cpp' at line 739
When it goes on to send a report to Apple it flashes up so quick you can't send the report.
[report snipped]
Rayco
wav files
kJams does not yet support WAV+G file format. Yes, it will soon, but not yet. Don't try. They must be MP3+G files.
This could be the cause of your bug.
The "Apple Crash Reporter" dialog, which reports directly to Apple, is *supposed* to disappear, because it is replaced by the "kJams Bug Reporter", which reports directly to me. Please don't post crash report call stacks in the forums, use the bug reporter or regular email for that.
