Option to fade audio when volume slider changed
Useful for talkback mics. When you want to talk over a track, you have the option of clicking anywhere in the volume slider, and instead of audio instantly changing, it fades to that level smoothly.
Re: Option to fade audio when volume slider changed
good idea
Inspired by "chart research". A feature of some programs to use when you (the DJ) are talking into the talkback mic so you can be heard, or, (as part of a combo of things) to gently get rid of a "problem" singer.
Me, I just use the mixer!
