Remove Producer Plugin on upgrade past 1.0b1
On upgrading kJams from a version pre 1.0b1 (Nov 14, 2014) it would be useful to have the kJams boot up sequence (or at some other point) check to see if the plug in is there, and delete it, since, AFAICT it has been deprecated.
Re: Remove Producer Plugin on upgrade past 1.0b1
mmm, yeah, that's one of those "this doesn't affect anyone, nobody will ever notice, or care, and it's definitely not worth my time" kinda things?
Hey, you're the one that said getting rid of cruft is a good thing! :)
yes, definitely. when it doesn't take any time, testing, or have the possibility of introducing new bugs ;-)
