Hack to fix switching audio source crash bug
Re: Hack to fix switching audio source crash bug
If by "see" you mean "physically", sure, but if by "see" you mean able to connect to it as a secondary monitor, then that does not recreate the bug.
i mean i could not physically see the monitor connected to the ATV, but the computer could see the ATV monitor as if it were a second display.
For all that care:
Fixed!
Now that was a hard bug to track down!
aaaaaaaaaand the problem was i was using a flippin' DEPRECATED CARBON call to play an 'snd' resource (eg: the "camera snapshot" or "rip completed" sounds) You know, Carbon Toolbox APIs, from the MacOS 9 era? sheesh.
updated that 4 lines of code to use Cocoa instead, and BOOM! fixed! The problem was that the carbon call left an audiolistener allocated and regularly polled, on the channel that played the sound, and also did not have Cocoa exception handling protection. so if that port ever got switched later, you'd crash.
