Restoring Old Kjams to New MacbookPro
guitartattooman
Post by guitartattooman »
Can I restore my old Kjams library and Histories to a New Macbook Pro from an external backup of my old Macbook Pro?
I deactivated Kjams license and wiped old MacbookPro clean and sold it.
I've installed Kjams on my my new computer and license is working.
Is it possible to get Kjams working the same as it did on my old computer by moving files from a backup of the old computer which is an external drive?
Thanks Dave.
Re: Restoring Old Kjams to New MacbookPro
yes, the folder you need is the "kJams" folder from the Music folder.
you might also want to get your Preferences
guitartattooman
How do I get my "History" back? Thx in advance.
as i said, restore the "kJams" folder, that will get everything.
