KTP (iKaraoke TunePrompter) No Show of iTunes Music List
clempav
Post by clempav »
Has anyone else encountered this?
Open TunePrompter>Select Song> In the window that pops up that *used to* allow iTunes to populate the library list/playlists to choose the song the sync, no longer works.
I have tried clicking in the left column of that window on the Music (under Favorites); Music (under Media) and even clicking through the folders in these links to get down to the iTunes Music folder where all my music is located. But I just get to a window in TunePrompter that shows an iTunes icon in the top section and "Open iTunes to populate this list" in the bottom section of the window. iTunes IS open.
I know the iTunes library .xml file is the one that is supposed to allow other programs to read only the iTunes library list and TunePrompter used to do this flawlessly. I've even tried starting over from scratch: new iTunes library and importing only music to make sure I didn't import an old and maybe flawed .xml library file to no avail.
(Has iTunes 12.1 now disallowed third party software from read access? )
thanks for any enlightenment to fix this ....
clem
Re: KTP (iKaraoke TunePrompter) No Show of iTunes Music List
It says that you have to be running iTunes at the same time, for the list to be populated, however, even when i do have iTunes running in the background, the list will not populate.
well the solution is "don't do that".
just navigate into your iTunes folder manually (/Users/<you>/Music/iTunes/iTunes Music/...)
clempav
Post by clempav »
Bummer! Apple! <:(
Thanks Dave! Glad to know I'm not on the crazy train.... :)
:o
