Persistence of rotation screen
If you are at the end of a track, and attempt to skip to the next one (either via UI or arrow key) and then respond to the confirmation dialogue just as the Rotation Screen in transitioning, and immediately try to play the next track (so, e.g., right arrow key, return, spacebar in rapid succession while rotation screen is transitioning) the Rotation screen does not auto fade on the next track, and must be manually taken down.
This is a fairly common occurrence, as you can probably imagine, in many scenarios. (Been tracking this one for a while now.)
Re: Persistence of rotation screen
i'll check it out and report back here
i assume you have these prefs on:
pause between tracks
skip silence at start of song
warn if current song will be interrupted
when ever i tried to reproduce the bug, i could not.
Yes, those prefs are turned on (and I can repro on different machines).
Also, sometimes it gets stuck in a playback loop, where it plays from 0:00 to 0:02 and then resets to 0:00 and repeats.
Sent you a video via e-mail.
both fixed
