Singer tri-pane view
Since the singer list and the tonight list bring up essentially the same view, and since tonight lists are rather short, and favorites lists are often nonexistent, it would be not only nice, but rather helpful, if the singer list could bring up a tri-pane view, with Tonight on top, a separator, Favourites in the middle, another separator, and History on the bottom. This would facilitate copying tracks between the playlist, and make it take far fewer clicks.
Re: Singer tri-pane view
the eventual plan is to have fully customizable panel layout, like adobe apps.
so you could do that but you could do anything else too.
not soon, however. fast search comes first
