lost pitch/key changes
natblend
Post by natblend »
half way through the show tonight, all the pitch changes that have been saved for years all disappeared. All Singers, I was hoping a restart would bring them back. no luck. Any idea what I might have done?
natblend
Re: lost pitch/key changes
Post by natblend »
I should mention, they only thing I've done different is recently added about 600 songs. I'm up to 9600 is all. I haven't consolidated yet.
natblend
Post by natblend »
OK. I just discovered, When I dropped the pitch -3 on Unchained Melody in one singers folder, it changed the same song in other singers folders.
That's not good.
i'm not seeing that.
note that if you select 3 singers then set the pitch, it will change the pitch for the whole selection.
how, exactly, are you doing it?
natblend
Post by natblend »
I'm changing pitches in singers favorites folders. They would always be saved. Now, if a different singer has the same song in their favorites, the pitch on that song will be what ever I set it on last. In other words. Changing pitches in one singers fav folder is now Universal. It changes that song pitch in the main library also.
Okay wow that totally sound like a bug! Armed with this valuable information, i shall investigate!
Update: Fixed. will be in the next release, or get the rouge now
natblend
Post by natblend »
Great. My regulars were pissed at me when they had to sing way out of their comfort key.
I added A Pitch column to the rotation window/folder, just so I wouldn't hurt anybody, including me.
natblend
Post by natblend »
Dave, I think we lost it again. Pitch changes are universal again.
I'm using 41R2.
I haven't updated to the latest yet
always update to latest before reporting a problem, the problem may be fixed!
in this case, it is fixed.
natblend
Post by natblend »
Great, thanks Dave.
I didn't see the update until I booted up at showtime. I'm always reluctant to upgrade with 5 minutes to start.
That backfired on me this time.
I did notice that all the pitch changes for all my singers stayed shifted in the main Library.
I had to change those back to 0.
Everything is working great,All is good.
:D
