iPad Display
mcfann1013
iPad Display
Post by mcfann1013 »
I have an iPad Air and want to use it as the singers monitor as well as have a bigger monitor for the audience. Are there holders for the Ipad Air that attach to a mic stand and is it pretty reliable as a monitor for kjams? I haven't tried to download idisplay yet. Just wondering how hard it all is to get set up.
Re: Ipad Display
Gosh i have no idea. Tried google? Anyone else care to chime in here?
is [an iPad a] pretty reliable as a monitor for kjams
yes, totally (using iDisplay), and it's easy to set up
Re: Ipad Display
There are dozens, all a quick Google search away:
search "ipad mic stand holder".
Re: Ipad Display
Re: Ipad Display
Up-Update: iDisplay actually COULD BE FIXED when macOS 10.14 (Mojave) comes out!
Re: iPad Display
Up-Up-Update: well it seems it may ALREADY be fixed? You just have to get the update and then reinstall and give permission for the KEXT to load?
