Change scrubber while attached to cursor
Any way to modify the scrubber while it is actively being scrubbed/connected to the cursor? Like make it hollow, different shape, colour, pulse, what have you. This will help prevent those embarrassing moments when you accidentally "tap to mouse down" on the scrubber, and 30 seconds later move the mouse, which is now attached to the cursor, and scrub the song out from under the singer!
Re: Change scrubber while attached to cursor
yes, anything is possible, but at this very late stage "no new features" is the rule. may i suggest turning off "tap to click", which i personally totally hate anyway. i realize you might love it (except for this problem), sorry about that.
Oh well, was hoping it was just a resource swap and few lines of code.
Feel free to preface any posts here with "assuming it is trivial…"
it probably would be a few lines of code, but during late beta, zero lines of code is the rule, except for critical bug fixes.
remind me again after 1.0 :D
