Song List Generator
Krisko
Song List Generator
Post by Krisko »
Hey guys... probably a question that's been asked a billion times, but I can't find it. I bough kJams a few months back and used it to rip the remaining 200 discs I had left (cause lets be honest... it's waaaay easier)
The bulk of my selection had already been renamed to suit SLG, but the songs I ripped with kJams are not... I think it has something to do with spaces between dashes.
SLG: L-T - R - S
kJams: L-T-R-S
I found where I can change "Conform Song names" but it doesn't change what's already ripped. Is there a way I can change these all without going through them 1 by 1?
I should have checked first :/
Re: Song List Generator
first, what is "SLG"? and why do you care? doesn't kJams cover your needs?
but yes, create a new template with "L-T - R - S", set that as your new conform template.
then select the songs you want to update, then "push file names"
Krisko
Post by Krisko »
Hi dave!
SLG - Song List Generator is just the program I use to make my books. It's easy to use and easy on the eyes for the customers.
I did what you asked, but it still wouldn't put in the spaces I need for the spaces in. Ok.. if I can't get this to work, is there a way to take out multiple listings of a song so that when I copy/paste into an Excell type program, I won't have 5 Shania Twain "Any Man Of Mine" 's ? lol
wow don't give up so easily. it should work. if it doesn't it's a bug that i'll fix so it DOES work.
are you available tomorrow night? can we get on the fone?
call me during office hours (fone number is on that page)
Krisko
Post by Krisko »
Hey Dave!! Sorry.. I didn't get this, I'm working over night tonight.
Are you around tomorrow? I can prolly give a call tomorrow night :)
i don't have office hours on friday. click the link to see when to call :)
