Editing the manufacturer data field
ostadler
Post by ostadler »
Hello all,
I just wonder how I can conveniently mass-edit the manufacturer data field for my songs. When I purchase a song online this field is automatically set, but when I manually ad songs to my library I only have a "-" in this field. When editing title information I cant access this field. Is there a way to edit this?
Thanks a lot for help,
many greetings from Germany,
Oliver
Re: Editing the manufacturer data field
just select all the ones you want to change, then click on the dash of one of the Manufacturer fields, then change it. kJams will ask if you want to change them all.
ostadler
Post by ostadler »
Hi Dave,
Thanks!! That works like a charm, awesome!!
Many greetings,
Oliver
