Setting Meta data
Setting Meta data
In the past there was a short cut that could be used to confirm that the meta data could be set for all the songs highlighted when editing tracks. Now I get the option to click Change All, Just One, or Cancel and I have to click Change All whereas several versions ago I could use a short cut to change all.
Is there any way of getting it back
Re: Setting Meta data
the key "A" on your keyboard is the shortcut to press to activate the "Change All" button
Doesn't work for me
oops. right. bug. fixing.
