Help correct my lagging
TheWarrior97
Post by TheWarrior97 »
This is what I am working with:
-Windows 7 (32bit)
-Intel E660 dual core 2.40GHz@1066 4MB Cache (64bit)
-4GB Ram PC2-6400 DDR2-800
-Intel SSD X25-M 80gb (operating system)
-Radeon HD 5670 512mB 128-bit GDDR5 PCI Express 2.1x16
-Asus MB P5W DH Deluxe
-Seasonic 700W Power Supply
-WD Caviar Green 2TB (karaoke library)
My computer really lags when I am playing the program. Lyrics get choppy, program constantly freezes, search box takes a few seconds to load results. I do have the slow searching checked but the pre-cache is checked and the high resolution is unchecked. The memory checker doesn't seem to surpass 2gb when playing a song.
What needs upgraded to make the most bang for my buck and get this software running smoother on my machine.
Thanks in advance
Re: Help correct my lagging
let's get on the phone, there's no good way to do this over email.
call me during office hours and we'll get this all sorted. if you're not available then, email me with when you can be available and we'll work something out.
