Songs not rendered
garfield2344
Songs not rendered
Post by garfield2344 »
I have a several songs that showed up in songs not renamed folder. The songs are in my library but I want to delete the not renamed folder. Why are they showing up there? Can I delete the not renamed folders all at once or do I have to do it one at a time? There is one song in each not renamed folder but I have several folders. The folder looks like a page with a music note on it and it is titled songs not renamed.
Re: Songs not rendered
first, you're talking about "Playlists", not folders. it can be confusing unless you use the correct terminology.
second, this is normal. check out the article.
