wtkJams 1.0.3 now available on the App Store
djunod
Post by djunod »
wtkJams can be used to connect to any Karaoke venue that uses the kJams software. You can use wtkJams to search for songs by Artist or Title, add yourself to the rotation, maintain a list of your favorite songs, and view your song history, all from your iPhone, iPod Touch or iPad. Brought to you by http://www.WheresTheKaraoke.com
Version 1.0.3 takes care of some minor issues, plus an annoying bug that has been in there since the beginning.
Link to wtkJams on the App Store: http://itunes.apple.com/us/app/wtkjams/id494844875
Thanks for checking it out!
Re: wtkJams 1.0.3 now available on the App Store
Dwartz
Post by Dwartz »
What is the difference between iJams & wtkJams?
wtkJams is in active development and is a bit prettier, has fewer bugs, and is being expanded now to allow the showing of the Rotation (so you can see when you sing)
screen shots:
http://kjams.com/wiki/wtkJams
http://kjams.com/wiki/ijams
