File Export Problem
File Export Problem
Attempted to export "all files" in playlist with kJams R35 version.
No Go... zip MPG files failed to export.
can you check this menu item... I had no problem on prevvious versions.
thanks
thanks
Re: File Export Problem
send me the log file from that session. if you can't find that, just do the operation again, then after it fails: help->send log file
Dave.
emailed you log file
did you receive? ... if not I'll send again
no, i got no bug report or log file from any "frank"
sent you another bug log file Wed 25th.
did you receive?
did you receive?
please just send me a regular email. once we establish that we're talking over email, THEN send me the file.
and no, i did not see any report
Dave,
Received your email.
Playlist files are linked ok. Files play normally.
Can export xml, csv, Cue & BIN files normally but CANNOT export audio or zip mpg files.
However when I use an earlier version kJams R28, the files in the same playlist export normally as expected
Ami I missing a preference setting in the latest R37 version??
i think you misunderstand. please reply VIA EMAIL, and in that email, tell me that you're this person on the forums. we'll go from there.
Dave,
Sent you email around 4th or 5th via your "Help" menu item. Email contained log file of failed operation.
Haven't heard from you.. maybe email not getting through for some reason.
File export problem still persists in version R37. Meantime, I'm using old kJams version R28 as workaround.
hmm, i did not get the email. please send again.
sent email again 2 days ago
what's up D?
what's up D?
sorry, i've been sick the last 2 days
i see your log file, interestingly it showed nothing. i think we should just get on the phone and hammer it out on the spot. are you available sunday night after 6pm pacific time?
Yes I will be available
my number is 215-679-6451(in PA)
okay, can you call me on sunday then after 6pm pacific time? (that's 9pm your time)
Dave
I've sort of given up on this problem.
Since I infrequently export MP3G zip files, I've settled on using an older version R28 to perform this operation. This version exports normally and will suffice for my needs.
PS Just as an added note, I've updated to version version R41 which still fails to export "all files".
