Having trouble sharing my library
captainkaraoke
Post by captainkaraoke »
I recently bought kJams Pro, and have been extremely happy with it. However, when 1 of my regulars downloaded the ap for his iPhone, he couldn't see my library to pick songs. He showed up in my rotation, but that was it. I had to add songs manually. I went to the settings page to make sure that I had set everything up properly for the network. I noticed that "share library" was unchecked. I tried to check it, but it was greyed out. I'm wondering if I did/did not do something in the initial set-up that caused this, or if I just overlooked something that I was supposed to do to set up the network. Any help would be fantastic.
Re: Having trouble sharing my library
the iphone user must be on the same wifi network as the mac. try again and let me know.
captainkaraoke
Tried again and everything worked fine. The issue had more to do with my lack of understanding of the app, than anything set-up wise being wrong. I thought they would be able to scroll through my library like I can. That was where the misunderstanding was. They are able to search for songs and sign up just fine. Thanks for your help!
:D
