I'm new to the karaoke world. I'm trying to put together a PC based karaoke system to use for parties. I've downloaded both kjams lite and kjams pro and at launch i keep getting the following error
C:\Program Files (x86)\kJams Lite.app\Contents\Windows\kJams Lite.exe
The application has failed to start because its side-by-side configuration is incorrect. Please
see the application event log or use the command-line sxstrace.exe tool for more detail.
Please help, I've tried everything I can think of to make it work with no success. I am running a 64bit windows 7 PC.
Thank you
kJams for Windows wont launch
Re: kjams wont launch
To the rescue: The Instructions!
airbornejay
that did the trick! thanks
