Still Can't Export after upgrading to Lion
CiJay
Post by CiJay »
Still having no luck in exporting Karaoke files into my Itunes for use on my iPad or iPhone after upgrading to Lion....uggghhh :x
Most recent report I get when trying to export is, "couldn't get required component" I have not moved any files since my original installation.
Is it possible to just clear my KJams Library; like starting over without losing all of my Karaoke files/folders that were created on my external hard drive??? My thought was to clear the program, move my Karaoke Folder from the external hard drive into the main hard drive next to KJams in the same folder and re import the folder contents into KJams.
Help!!!!
Re: Still Can't Export after upgrading to Lion
CiJay
Post by CiJay »
Excellent!!! Thank you for the fix!!!
