Reverb
weezer1000000
Reverb
Post by weezer1000000 »
Does anyone know of a free reverb program for Mac download that works with KJams?
Re: Reverb
Garage Band is built in to most macs nowadays right?
weezer1000000
Re: Reverb
Thank you. I hadn't thought of that. I know how to record on Garage Band, but how do I incorporate the reverb into KJams to use for the singing voice?
Re: Reverb
you don't use kJams at all for the mic, you only use GarageBand. and GB has reverb.
weezer1000000
Re: Reverb
I set up the reverb in Garage Band. When I sing on a song from KJams there is no reverb on my voice. What am I doing wrong?
Re: Reverb
if you set up the reverb in GB for your mic, then it's working. if it's not working, then you didn't set it up. google for help on garage band.
GB has nothing at all to do with kJams. kJams only plays the song audio. be sure to turn OFF the mic input in kJams.
