Producer Dropping Files
franks
Post by franks »
I am not sure what is happening.
I make a new karaoke song with Producer and I save data base before quitting Producer.
Next, I play the new song from the kjams library and it plays great!
All the templates and graphics are there and every thing is good!
Now I shut my computer down and the next day I try to play the same song from the library and.......there is no clean startup.
It gives message "Converting media stream" followed by "no template found".
I checked folder in kjams where all my graphics are located and they are all there.
Checked library for templates looks like some are missing.
I have to start over again. I remove song from library and re-import KTP file.; then open Producer and repeat process.
Then the same story happens.
I must be missing a step somwhere... need help
Re: Producer Dropping Files
this is not something that can be solved in the forums. please contact me directly.
