karaoke file
Phil Dowling
karaoke file
Post by Phil Dowling »
Hi
The karaoke folder with my zipped cdg files in.. does kjams change or add anything in it plz
thx
Re: karaoke file
i am not entirely sure what you're saying.
are you asking about the "kJams Music" folder that kJams creates? or are you talking about your own folder that you already had, that you "added to library"? in the former case, kJams will add any music you rip from disc or buy from a built in music store. in both cases kjams will change the file names of the songs if you change the names inside kjams. kjams presently does NOT keep the "kJams Music" folder organized (ie: it does not move songs to different folders if you change the artist or album)
Phil Dowling
Re: karaoke file
Hi
thx for reply im talking about my hard drive of karaoke that i have add to my library
if i change the name of the karaoke song by using the reinterpret names does anything change in my zip file plz
Re: karaoke file
yes, kjams will unzip the file, update the ID3 tags of the zip file, re-zip the file, and rename the zip file to conform to the new name.
Phil Dowling
Re: karaoke file
thx 4 ur answer
Re: karaoke file
ur wlkm
