kma files
Re: kma files
i will play them. and i suppose it will convert them too. give it a try.
load it up then select it and go special -> convert to [whatever your encoder is]
Re: kma files
thats exactly what i've done . kjams says it could not convert because it is not a cdg.
Re: kma files
oh, right, now i remember. right kJams actually doesn't allow you to convert KMA files or MCG / NCG files to Audio+G. I did that because these file formats are really owned by someone else and they'd probably be upset for allowing that. Can i ask why you need to convert them if kJams can already play them?
