Loading Songs on to Mac
JoeC
Post by JoeC »
I am buying a lot of music which I want to use on my Mac with Kjams. I read in the docs that I should place all of the music in a separate folder on the Mac for access by Kjams. I will be uploading it from a terra byte portable Hard drive. Should I purchase KJams Pro first? How should I proceed with loading my music? Thanks.
Re: Loading Songs on to Mac
Be sure the music has lyrics. For example the "karaoke" that iTunes sells has no lyrics. Use the built in music stores instead. You do not have to buy first. Btw when you say "upload" I think you mean "add to library"
http://karaoke.kjams.com/wiki/Glossary
http://karaoke.kjams.com/wiki/Add_To_Library%E2%80%A6
JoeC
Post by JoeC »
Thanks, Dave. I appreciate the help.
