UPDATE: Transfer Singer function now FULLY automated!
I wrote previously about the script I wrote to move singers between venues. Originally this script only automated the process of making the aliases and copying them between venues. Thanks to some terrific work by Dave, writing venue reloading into the code, and exposing it to scripting, I was able to fully automate this procedure!
Please read my original post here:
viewtopic.php?f=1&t=1377
And then proceed to the code wiki.
Re: UPDATE: Transfer Singer function now FULLY automated!
note: this won't work for y'all 'till the new update is released (r37) sometime next week. but yeah, that!
way2fst4u
Post by way2fst4u »
The action "Run AppleScript" Encountered an error
I had this working fine in a previous release...I am using 1.0a1r9
kJams Singer Venue.workflow.zip
(62.31 KiB) Downloaded 690 times
Scott
is that a question?
way2fst4u
Post by way2fst4u »
I had this working several releases ago, and have not used it in the last few releases. I cannot say for sure which release or even if that is what's caused the error and causing this to no longer work. Have you seen this error? Can you tell by the workflow I have posted that I have done it correctly?
Is that better Dave? ;)
Scott
Scott
Are you sure that the path to your kJams Library is correct?
set kJamsPath to "/Volumes/DJ Drive/kJams/kJams Library/"
Where are you getting the error? Try running inside of Automator and see where exactly the script errors out.
way2fst4u
Post by way2fst4u »
I got "Doesn't understand the do command reference"
docommand kScriptCommand_RESCAN_VENUE
Scott
did you define it?
set kScriptCommand_RESCAN_VENUE to 19
way2fst4u
Post by way2fst4u »
I just followed the directions...copied & pasted then changed the path.
Scott
well, okay, i'll ask it different: is it defined in what you have now?
way2fst4u
Post by way2fst4u »
Yes it is defined. I found the problem!
You cannot use this script on a new venue with NO singers. Once you put one in manually, it works fine. I guess because when you create a venue, until you add a singer manually, there is no "Singers" folder? In any case, I added one, then tried again, and it works on both machines now. Thank you for your help Dave.
Scott
yay!
