Capability to Search in the Comment Field
swainner
Post by swainner »
Dave,
I chose to use the Comment field in the metadata for tracking disks in our filing shelves (each disk is numbered). I tried to do a search for a specific disk number, but the results of the search are empty. When I remove the search criteria, all the songs in the library are listed. I can sort by disk number (i.e. Comment field contents), but I was hoping to search for a specific disk without having to scroll through pages of entries to get to a disk of interest.
Scott
Re: Capability to Search in the Comment Field
if you type a pure number in the search field, kJams only searches numeric columns (like track number, PLI, Song ID etc). and the comment field is NOT numeric. to search for a string of characters the LOOKS like a number, add a space to the end.
http://karaoke.kjams.com/wiki/Searching
swainner
Post by swainner »
Worked perfectly. Thanks for clarifying Dave. I didn't understand that the definition of the field (not the characters in the field) determined the search criteria.
