Tricera music store
Tricera music store
Sometimes when i click on a song to listen to a sample. it doesn't play. Anyone else experiencing this?
Re: Tricera music store
does it always happen for the same song? if so, what song?
It has happened with several songs in the past, i figured it was my connection. The one i tried last night was Born free by Matt Munro. Tried it again this morning with same reesults.
just tried that song.
searched and found 2 hits.
both played fine.
but note: the audio is SILENT for the first 9.5 seconds! that's right, you have to wait almost TEN SECONDS to hear anything, after it starts playing
both played fine.
Strange, yes i know i need to wait about ten seconds for most songs to start playing. Problem is, it never starts playing. When i double click a song that will play, i notice it starts loading then starts to play automatically and you see the pause button while it plays. With this song and many others i try to play, it never loads. It just shows the player with the play button visible. If i click on the play button after waiting a minute or more, still nothing happens. I tried to refresh several times but this doesn't help either. Any settings in my browser that could be making this happen or another player settings affecting this one? I will test this out on my macbook also.
Tried to play born free on my macbook and it worked fine the first time but when i tried it a second time it does not work?? Something is screwy here!
i don't know what to say other than it worked fine for me.
if you can provably reproduce the problem, get me on ichat and i'll have a look
