apple menu
paul hewett
apple menu
Hey Dave, While using kjams I have no response from the apple, file, edit... menus . All seems fine while using safari or other programs. any suggestions ?
Re: apple menu
are you sure? quit and run again. if you have to force quit, it's probably some other problem. does it still happen?
paul hewett
Re: apple menu
no force quit under the apple. will not drop down. I have to shut kjams down with the apple key and q.
Re: apple menu
well the point is, don't use kJams to access the apple menu to get to the force quit. go to the finder, and use the apple menu from thereno force quit under the apple. will not drop down
okay so you're saying that the menu commands are still working? so did kJams quit when you did that?I have to shut kjams down with the apple key and q.
and then, when you run again, is everything fine? or are you still having trouble?
paul hewett
Re: apple menu
force quit works fine in finder. after restarting kjams nothing has changed.
Re: apple menu
by "nothing has changed" do you mean that you still can't access the menus?
if so, try this: quit kjams, then go to your Music folder and find the folder "kJams". inside that is a folder called "kJams Library". put a tilde in front of it like this "~kJams Library", then run. if it runs fine, then email me that "~kJams Library" folder and i'll figure it out. if that does NOT work, delete the newly created "kJams Library" and remove the tilde from the other one, then go to your home folder then into "Library/Preferences/kJams", and find the file "kJams Preferences". put a tilde in front of THAT, then run. if it THEN runs fine, send me the prefs file. if it STILL doesn't work, trash the new prefs and remove the tilde from the old prefs, then get me on ichat on monday and i'll personally deal with it.
how to get me on ichat:
paul hewett
Re: apple menu
You are the man. it was in the preference plist. e-mailed file to you. thanks dave
Re: apple menu
thanks for sending the prefs file, i've found and fixed the bug
