Search field persistence
gsteffens
Post by gsteffens »
As I was searching for songs in my Library and then in the Music Stores I found that each time I changed locations (Library, Karaoke Locker, TriceraSoft) I had to retype my search criteria. Is there any way that the search field can be retained when moving between different areas of kJams but not actually perform the search until you click the Search button?
Re: Search field persistence
no, if you keep the search term, it will always perform the search.
type your search, then select all and copy.
then when you switch playlists, command f, command v, to find and paste your previous search
