Volume settings explanation or help?
dizzidecazz
Post by dizzidecazz »
Hi,
I've got my song levels mostly balanced using this, http://homepage.mac.com/beryrinaldo/Aud ... acMP3Gain/. Some are still a little bit quieter than others and I want to use the Remember Song Volume setting to boost them. I'm not sure how to set the overall or default volume to less than 100%. If I set the volume slider to around 80% and then increase the volume of a particular song to 95% using the Remember Song Volume setting, the overall volume stays at 95% for the subsequent songs, making them louder than I want. So I want to either set the overall volume to return to a default level, or I'd be happy to set all songs Remembered value to 80% so I have room to cut or boost as needed. I tried selecting all but couldn't edit the value.
Can I?
Diz
Re: Volume settings explanation or help?
that's a bug. it should "go back to default" after every song.
